- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best orbi settings/Advanced settings as of 2019?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best orbi settings/Advanced settings as of 2019?
my settings should i change anything for better relablity because thats my problem right now
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
How many satellites do you have?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the latest firmware I have 1 router and 1 satellite my house is 3500 squft I have 3 floors upstairs downstairs and basmenet but im upstairs right next to the satilete and the router is downstirs 50ft to 60ft away
- Mark as New
- Bookmark
- Subscribe
- Permalink
my channel for 2.4 ghz is auto
and my 5ghz is 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @adikm,
The best settings is Orbi default settings. You can enable those 3 Advanced settings for enhanced or new features if they don't wreak havoc in your WiFi network. Also, if your Satellites are within the WiFi range of your Orbi Router, please disable Daisy-Chain feature since it won't help and will only hurt.
BTW, what sort of reliable problem do you currently have with your Orbi setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Infact, that's exactly how my RBK50 is setup. Same as screenshot but with daisychain turned off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For 5GHz I make more of an effort to look at the spectrum to ensure no other router is stepping on the channel I’m using and manually controlling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So everything has been going good but there has been little lagspikes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cant it wont allow me
to click on it
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe uPnP would be already disabled in AP mode. Thats only available in router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ill give it 24 hours and see what happens
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully it stablizes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes and how long wil that take
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give it some time. Day or two? Keep us posted on what you see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok its been a full day internet is good it's just packet loss thats causing these problems you know how to fix packet loss on orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Download pingplotter.com on to a PC. Wire connect the PC directly to the ISP modem first and test with out the Orbi connected. Test from PC to modem them from modem to the pingplotter.com site. Then connect the Orbi to the modem and the PC to the Orbi. Ping the Orbi first, then the modem thru the Orbi then pingplotter site thru both Orbi and modem. I would recommend doing this while ALL other devices are turned OFF and not connected. Just the wired PC alone.
Checking for any packlet loss and errors along the way at each stage as you test. Review the pingplotter site for information on what to look for.
Singal from ISP can be an issue. ISP Cabling up to the modem can be an issue. Modem can be an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok so i did all of that and it was normal but i do have a router downstairs a netgear one but upstairs i have a modem connected to my router and the router connected to the satiltte
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please explain me why disable it??
Thanks
