- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Best orbi settings/Advanced settings as of 2019?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best orbi settings/Advanced settings as of 2019?
@dbandit wrote:Could you please explain me why disable it??
People may be able to give a better response if you explain what "it" refers to. I like to space down (to create some space), go back and click on Quote (above right), and then delete what it not relevant. There has not been any activity on this thread since May, so it is not entirely obvious which previous comment you are referring to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My bad, i was referring to Daisy-Chain feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi comes from the factory with the Daisy Chain feature turned on, even when the package includes a router and only one satellite. Thousands of customers purchase it this way, and it seems to work for them (I did, and it does.)
However, activating Daisy Chain also turns on a separate 5G backhaul channel, which is of no use when there is only one satellite. And, if there happen to be more than one satellite and they are not actually "chained", then it is still a waste. Many customers have "wired" their satellites to the router (lucky sods, having WIRE IN THE WALLS!) Daisy Chain makes no sense for them, either.
So, if there is no practical value in having Daisy Chain enabled, by all means turn it off. Just remember what you did in case you later purchase another satellite and it will be so far from the router that it needs Daisy Chain. If the feature is needed and is turned off, then that satellite won't work well.
- « Previous
- 1
- 2
- Next »
