Orbi WiFi 7 RBE973
Reply
Block just internet access
nagendraprasath
Hi,
How do i block just internet access to a local NAS.
In Advanced -> Security -> Access Control only has option to block or allow.
When i block it just blocks even LAN access but i just  want to block traffic
from or to WAN side.
I used Asus routers and its been every easy
to block internet access and allow LAN access...
But couldnt find the same in so expensive Netgear Orbi 😞
Let me know if i'm overlooking or Its a limitation! Thanks!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Block just internet access
Have you tried "Block Services" on that single IP?
(Advanced Tab->Security->Block Services.  Drop down to "Any" and put in the single IP address.)
When I set up servers (in the past, looong ago) I was able to define Firewall rules in the server to block access by IP address.  i.e. block "everything" and then allow 192.168.1.1/24.  Do not own a NAS now, so have no idea what configuration options they have typically.
Message 2 of 3
This local NAS is?
On my ZyXel and dLink control of that sort of thing is within the NAS.
Then there is the fact that "internet access" could be one of many things.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2120 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
