- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000 ethernet ports do not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the C7000 and I am able to connect via wifi, but will not connect using the ethernet ports. I have a green light at the Ethernet port, however anthing used in any of the ports will not connect to internet. My security system, phone, and tv that are plugged into them says no internet connection. I connect my Mac or any other wifi device using wifi, I have contacted my internet service provider and they checked everything on their end and all is working. do you have any suggestions I can try
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000 ethernet ports do not work
Hello Softballcoach
I suggest contacting Netgear support if the modem is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
