TimDragonFire
Mar 31, 2020Follower
CAN MY CBR40 BE USED AS A WIRELESS ACCESS POINT?
Hello
i have an orbi cbr40 with satellite with comcast xfinity internet however they tell me it is not compatible with gig speeds so they are letting me use one of their modems . i would like to use my orbi as the acesss point still
can this be done with the CBR40 and satellite and if so could you provide me simple to follow instructions?
thanks
Tim
1 Reply
It can not unforunately. Only in gateway or modem mode only.
Please be sure to post in the Orbi with Cable modem forum for your future needs:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Good Luck.
