- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAT 6 shielded cable leads to RBR50 connectivity issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have long runs of cat6 shielded cable connecting to our RBR50, running to RBS50's. The cable is really stiff, and after about 3-4 months we have had several connectivity issues over those ports. I am guessing here, but it seems like the problem is that the cable bends at the location of the router exert a torque on the cat6 socket in the RBR50 that is too much. I rerouted the cables and temporarily have it fixed. What I am looking for is a home-grade cable tray that would support the cable bends and feed the cable directly to the router. Are such products available?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAT 6 shielded cable leads to RBR50 connectivity issues
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
Is Daisy Chain enabled by chance? If so, please disable this feature on the RBR.
At most CAT6 plain STP patch cables are all that are needed. I think some mfr in cabling vary so some may be stiffer than others. If you have something that is stiff, you might check into putting a non managed non green ethernet switch or a barrel connecor near the RBS and then install more flexible CAT6 patch cable, say 2-4 feet length.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you got it fixed then.
Yes, ISP control FW updates on cable modems. There are no user FW updates.
Glad all other is working. Mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only remaining question i have is how to solve the issue of unruly Ethernet cables that run from a conduit in the floor to the entertainment center. When the house was built, Ethernet was not commonly installed. I'm thinking that what I need to do is create a mini-patch panel in a j-box on the wall near the entertainment center and terminate the incoming Ethernet cable there, install the switch there, and then run flexible cable to the entertainment center.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suggest installing a small 4 or 8 port unmanaged gigabit switch behind your entertainment center, with the stiff CAT6 cable feeding into it. Mount it on the wall so that the stiff cable is not flexed on the connection. Then use flexible 4 foot or so CAT6 or CAT5e patch cables to go to wired network ports of your satellite, Blu-ray player, Smart TV, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
LAN cables can be fished thru existing walls. Might ask a local cable ship or PC or electrician shop on if there is anyone that can help you with cable installation.
