Reply
CBS All Access not playing videos
mswells
I am unable to view shows in the CBS All Access App on Roku TV.or PC. Getting "Sorry this video is currently unavailable" error.
I have narrowed down the issue to my Orbi, since I am able to get it to work with my older router, just fine.
I am using the Orbi as an access point connected to my Netgear RT-N66U.  I also am able to stream other services like ABC, and NBC
without any issue...Just seeing the problem with CBS All Access.
Router Firmware v2.3.1.60
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Guru
Re: CBS All Access not playing videos
If your getting other streaming services from ABC and NBC and not thru CBS, maybe a streaming service issue. The Orbi in AP mode is working as a pass thru for data streams so its not blocking anything. Check with the configuration if your main host router and the streaming services.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 7
Guru
Any progress on this?
Testing
Message 3 of 7
mswells
Nope. No progress.  I ended up activating the wifi on my rt-n66 netgear router, and was able to get cbs all access to work.  I am currently using the rt-n66u for the Roku exlusively, and the orbi for the rest.  Wish I knew the answer though as to why it doesnt work thru the orbi completely.
Message 4 of 7
Guru
What is the Mfr and model# of the ISP modem the ASUS router is connected too?
Testing
Message 5 of 7
mswells
Firmware: 2.3.1.60
Cable Modem: Arris Surfboard  SB-8162+
Internet Provider: Cox in Phoenix, AZ
Asus RT-N66U Router connected to the Orbi RBK53, which is being used in AP Mode.
FYI:
Did not notice the problem in the previous firmware, 2.3.1.48
Message 6 of 7
Guru
Has a factory reset been performed and setup from scratch since v60 was applied? Might try this. Seen odd behaviors after FW updates and just continuing. Resets seem to clear out lingering bad code and configurations that can cause problems.
I would also try the Orbi in router mode connected directly to the ISP Modem since its just a modem  only and see if same thing still happens.
Testing
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1693 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
