× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 391 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Camera Connecting problems - Only one satellite will work
1 - D -Link Cams will not connect
2 - will work with only one satelitte.  When the 2nd is connected system goes down
Windows 10
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 3
Highlighted
Guru
Re: Camera Connecting problems - Only one satellite will work
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the model# of the Cameras?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Windows 10
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
NETGEAR Moderator
Hi @Reddog1954
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 3 of 3
