Orbi WiFi 7 RBE973
Reply
Can DNS servers be configured manually with DHCP IP?
EcoRam15
Hello, I have an Orbi RBR50, I'm trying to configure alternate DNS servers because my ISP's are terrible. However the option to manually configure DNS is disabled when the IP address is DHCP. I searched the community and it seems this should be possible. Is this recently locked down, or am I missing something? FW ver. 2.3.5.30
Message 1 of 6
Accepted Solutions
Guru
Re: Can DNS servers be configured manually with DHCP IP?
Any parental controls enabled?
What ISP service do you use? Cable, DSL or Fiber?
What FW version is currently loaded?
Message 4 of 6
All Replies
Guru
Yes you can set different DNS addresses. Under Advanced tab/Settings/Internet
Be sure any access controls are disabled if they are in use or the DNS entry fields maybe grayed out and not configurable.
Message 2 of 6
EcoRam15
That is my problem, the option to manually configure the DNS servers is grayed out when the IP address is set to DHCP, access control is not enabled.
Message 3 of 6
Guru
Message 4 of 6
EcoRam15
Thank you, it was the Circle parental controls that had it locked for some reason. As a work around, I was able to disable circle, change the dhcp settings, and re-enable circle and it kept the manual dns.
Thanks for your help!
Message 5 of 6
Guru
Good. Glad its working now.
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2243 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
