Orbi WiFi 7 RBE973
Reply
Can I change SUB NET MASK
rsisson
Ok, we used to have a GOOGLE Wifi system.
It defaulted to 192.168.86.x and this has been giving me fits as I go around the house and have to reprogram everything that is WiFi.
I have ONE device I can't reach, an IP camera on the side of the house.... I really don't want to have to take down for 5 min.
Can I change the SUBNET mask to -0- for a few minuets, pickup the OLD subnet, edit the node back to 192.168.1.X and the set the subnet back to 255?
PS... why is the subnet defaulting to 245 instead of 255?
Thanks...
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 8
Guru
Re: Can I change SUB NET MASK
Yes you should be able to set 192.168.86.x on the router.
https://www.aelius.com/njh/subnet_sheet.html
Message 2 of 8
rsisson
Not sure if you understood,   I don't want to -set- it to .86, I want to set it to -0- so it will pick up the old Google OnHub .86 net -AND- the new .1 net at the same time.
Everything I have read says I should be able to, but I just want to make sure before I screw up my network, again.
Message 3 of 8
Guru
Try it, if the UI doesn't like that subnet, then it will let you know when you try to apply it...
Message 4 of 8
st_shaw
Master
I don't know what you mean by setting the subnet mask to "-0-"  That doesn't make sense.
If you hardcoded an IP address into your camera (which is usually a bad idea) you can just temporarily set Orbi to use the 192.168.86.1/255.255.255.0 subnet. Then log into the camera, set the camera back to DHCP, then restore Orbi to whatever subnet you want.
If you must access 192.168.1.X and 192.168.86.X at the same time, then you could try to set Orbi to use 192.168.1.1/255.255.0.0.  However, Orbi may not accept that, as 192.168.1.X is usually used with a 255.255.255.0 subnet mask.
Message 5 of 8
rsisson
Alas it didn't work.
I set the Subnet to 255.255.0.0 hoping it would pick up the 192.168.86.?? address of the IP camera that was left stranded on that network.
I then ran a "Camera Finder" that uses MAC address and other network protocols I don't understand to find devices on the network with improper sub-nets and other addressing problems.  I have been able to login to several other devices that were corrupted, reset the address and reboot and have them reappear on the network.. Not this one.
I will have to dig out the ladder and the "security" screwdrivers (weird shaped screws) and take it down, reset it, and replace it.
this time we are leaving it DHCP, and we will just reserve an address for it in the router DHCP table.
Message 6 of 8
Guru
Do you have the old wifi system? If you do, why not set it up for long enough to get connection to the camera and make some changes...
Message 7 of 8
st_shaw
Master
You could try setting Orbi to use 192.168.86.1/255.255.255.0.  However, it sounds like there is a larger problem with that one camera, like maybe it's not connecting to WiFi at all.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3673 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
