Vkeosian45's avatar
Vkeosian45
Follower
Aug 22, 2021
Can I install Orbi pods with a Cox panaramic modem/router ?
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Of course. People do it all the time.
    Most of the time, having only a single router is a better overall solution than have two routers.
    https://kb.netgear.com/30186/What-is-Double-NAT
    My preferred solution is to put the vendor's device into "bridge" or "passthrough" mode and use the Orbi as my router.
    If changing the vendor's device is not possible, then putting the Orbi into Access Point (AP) mode can be useful.
