Orbi WiFi 7 RBE973
Reply
Can I use a spare router via wifi to add ports?
pburgh19
I have an RBK50 in my house that works well.  I have one remote room of my house that needs three wired/LAN ports, but I don't really want to drop another $200+ on an Orbi satellite.   Can I use a regular WiFi router to connect to the Orbi network to add the ports I need?  I wouldn't need to connect to the 2nd WiFI network -- it would only be there to add wired ports.
Thanks!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
guzzijason
Apprentice
Re: Can I use a spare router via wifi to add ports?
Yes, most routers will let you configure them as in "bridge mode", where they basically act as a WiFi client of your primary WiFi. Then you connect your wired devices to the bridged router as you like.
Message 2 of 3
pburgh19
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 438 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
