Reply
Can I use two RBS50 in 1 RBR50?
MStech
Hi All,
So I bought two RBK50 systems. Each system comes with 1 RBR50 (router) and 1 RBS50 (satellite). My question is, is it possible to use the 2 RBS50 to connect to the 1 RBR50? Or are the RBS50 paired only to the RBR50 that came together in the pack? Addittionally, can i setup the other 1 RBR50 as another satellite making the entire system as 1 router (RBR50) and 3 Satellites (2 RBS50 + 1 RBR50). Thanks in advance
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
Accepted Solutions
BBB73
Apprentice
Re: Can I use two RBS50 in 1 RBR50?
Hi,
you can have the 2 RBS50s as satellites for one of the RBR50s.
The 2nd RBR50 however cannot be used as satellite.
Message 2 of 5
All Replies
BBB73
Apprentice
Hi,
Message 2 of 5
MStech
Thanks for the quick reply. Can the 2nd RBR50 be used in AP mode?
Message 3 of 5
BBB73
Apprentice
Hi MStech, yes this is possible but please see @ekhalil ’s wise comments in this thread: https://community.netgear.com/t5/Orbi/Orbi-Router-as-a-wired-satellite-access-point-from-another/m-p...
Message 4 of 5
Chuck_M
Mentor
Additionally you can add more satellites... I bought the same pack as you and recently added a third satellite... works great.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1757 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
