Reply
Highlighted
Can Orbi App access to advance setting of Orbi?
Hi,
Can Orbi App access to the advance setting of Orbi? if so, how? I can just access to the basic setting. Can I do port forwarding on the Orbi App?
thanks in advance
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 8
Accepted Solutions
Highlighted
NETGEAR Moderator
Re: Can Orbi App access to advance setting of Orbi?
Message 6 of 8
All Replies
Highlighted
Guru
Any Advanced configurations need to be performed with a web browser and at the routers web pages.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 8
Highlighted
Thanks,
then is it possible for me to access the orbi router through internet remotely not through LAN  (by web browser not apps)?
Message 3 of 8
Highlighted
Guru
If you have Remote Management enabled.
Message 4 of 8
Highlighted
Mentor
You can enable remote management by going to your web gui (typically 192.168.1.1) then click ADVANCED tab then click ADVANCED SETUP on left side and then REMOTE MANAGEMENT
Put a check in TURN REMOTE MANAGEMENT ON and pay attention to your remote management address below that.
Note the port number that management is done by and where you can limit who can do remote access.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, RBS850), w/2 x RBS50) (Wired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 5 of 8
Highlighted
NETGEAR Moderator
Message 6 of 8
Highlighted
How do I access the Adfvance section when it is taking such a long time to appear when I log into the orbi website?
Message 7 of 8
Highlighted
Guru
Whats condidered a "long time"?
What browser are you using?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4134 views
  • 2 kudos
  • 5 in conversation
Announcements
