Orbi WiFi 7 RBE973
Reply
Can Orbi router work alone without satellite?
Vobuai
Follower
Hi I just want to know if Orbi router can work alone without the satellite or not?
Currently I am placing the router in living room and the satellite in bedroom. I want to switch-off the satellite at night when sleeping to reduce EMF radiation. But when I switch-off the satellite, it seem the entire network mesh got problem, so I have to switch-on the satellite again to get the network back to normal condition.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Accepted Solutions
rhester72
Virtuoso
Re: Can Orbi router work alone without satellite?
Yes, router-only is a supported configuration.
Any devices that were previously connected to the satellite should (eventually) auto-reconnect to the router.
If you are doing it exclusively for EMF reasons, though, it might be worth pointing out that the radiation generated (and absorbed by the human body) by cell phones and towers, radio stations, plane transponders, and the Sun already so grossly exceeds wifi's maximum that there is absolutely no risk in that regard.
Rodney
Message 2 of 2
All Replies
rhester72
Virtuoso
Rodney
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6340 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
