Orbi WiFi 7 RBE973
Reply
Can an add on satellite be added to an Orbi in AP Mode
Crew60
Hello
I have an Orbi Mesh RBR50 with 2 Satellites set up. In addition I have a RBR50 I have set up  in AP with a unique name and gets an IP from the Orbi RBR50 Main Router. It acts on its own name for the AP one.
I was wondering if you can add a Satellite to the Orbi RBR50 in AP mode and separate from the main Orbi Mesh. The satellite will be in the name of Router I have put in AP mode? Hope this does not sound confusing.
Thanks
Dave
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Can an add on satellite be added to an Orbi in AP Mode
Yes, when you press the sync button on the RBR thats in AP mode, then press the sync button on the RBS you wish to add to the RBR in AP mode, the RBS will connect to that RBR.
@Crew60 wrote:
Hello
Thanks
Dave
Message 2 of 5
Crew60
Can I just add the Sat via the Orbi app to add the Satellite to the AP also instead of the sync?
Message 3 of 5
CrimpOn
Guru
There is an entire forum devoted to the Orbi "app": https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
My concern with the app would be ensuring which Orbi the satellite was being added to (the primary Orbi or the AP Orbi).  If the app makes clear to you which one it is adding the satellite to, sounds good to me.  I also think that pressing two tiny buttons is pretty simple.
Message 4 of 5
Guru
I recommend adding the RBS to the 2nd RBR using the sync buttons to ensure the RBS is added to the correct RBR.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 11710 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
