Orbi WiFi 7 RBE973
Reply
Can no longer connect using orbilogin.com or entering 192.168.1.1
jonseff
Tutor
Having the exact same problem. Can no longer connect using orbilogin.com or entering 192.168.1.1 (tried three different Mac browsers and both http and https, as well as iPhone and iPad), or using the iOS app. Nothing sees my router as being connected, although my wired and wireless connections are all working just fine.
Message 1 of 3
Guru
Re: Can no longer connect using orbilogin.com or entering 192.168.1.1
What model Orbi do you have?
You need to factory reset the RBR and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Message 2 of 3
jonseff
Tutor
Thanks. I have an RBR750 with three satellites. Was hoping to fix this without nuking my whole system. Will have to fix when I have a bunch of free time and the kids out of the house so they won't complain about the Wi-Fi 😁.
This is my second Orbi setup (the first simply stopped putting out a wireless signal after several years) and probably my last.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 518 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
