- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can not find Orbi wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just got a new Orbi rbk50 system. Plugged it all in and ran it through app. Everything set up perfect, changed SSID/password and had great service even out in my barn....so happy. About 2 hours later, I noticed my phone was back on my ISP 5g instead of my new orbi wifi. Checked on wifi setting and my orbi SSID is no where to be found. I have tried everything I know of at this point but can not figure anything out. I rebooted/reset both the ISP modem and orbi router many times to no avail. The only thing I notice that is interesting is my ethernet port light on ISP modem is not lit all the time, but if I plug that same ethernet from ISP modem into my laptop, I get internet and the light is always on. Also, currently the ring light goes from solid white then will pulse white, go to green then amber then back to white. Please someone point me in the right direction, I'm not well versed on these systems so please try using layman terms for me. Thank you in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can not find Orbi wifi
What devices do you have connected?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sjp649 wrote:Just got a new Orbi rbk50 system. Plugged it all in and ran it through app. Everything set up perfect, changed SSID/password and had great service even out in my barn....so happy. using layman terms for me.
Since the laptop has an ethernet jack, you can plug the laptop into one of the Orbi LAN ports and connect to the Orbi web interface. Since you have two routers (the ISP and the Orbi), it is not clear what IP address the Orbi router will have. If the laptop is Windows, the "ipconfig /all" command (on the CMD: prompt) will show an IP for the "gateway", which is the Orbi.
Open a web browser and enter http://<ip of Orbi>. This should bring up the login screen where the admin ID is "admin" (always) and the password is whatever you set it to during setup (the default is "password", and users are badgered to change it to something more complicated). Note: this is NOT the WiFi password unless you deliberately made them the same.
The web interface will show what is going on with the Orbi in more detail than the "app".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sjp649 wrote:
Plugging in Ethernet from orbi to laptop doesn’t do anything. I don’t get any internet. I’m sure that’s because the Ethernet port on isp modem doesn’t stay connected. I have no idea. I’m at a loss
Talk to us about your modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh, dear. I had a similar experience last week where an Orbi satellite tried to update and then just died - DEAD. Since I was 3,000 miles from home and could not wait for a replacement, I resorted to the "TFTP Trick". (Trivial File Transfer Protocol) (Not for the faint of heart.) Basically, I downloaded the Orbi firmware to my laptop. Installed a TFTP client on the laptop. Disabled the d**m firewall. Connected laptop directly to the satellite. Used TFTP to push the firmware. And..... it came back to life! Here's the link that @FURRYe38 provided me: https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Please understand this was an ordeal, and I have been doing things like this for over 30 years.
If this is "new", I would send it back as defective and get a new one. Amazon and Costco take them back, "no questions". Where did it come from?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the tftp but the light on back did turn amber like it said it would and the server interface kept reverting to a loop switchback or something like that....nothing is working
- Mark as New
- Bookmark
- Subscribe
- Permalink
