Orbi WiFi 7 RBE973
Reply
Can’t Add multiroom music speakers to pair of echos on Orbi guest network
Jimdaff
Tutor
I have an Orbi RBR20 with a satellite. I am trying to get an amazon echo and an Echo dot to play the same music. I follow the steps on the echo app for “Add multiroom music speakers”. When I select the first echo the second one changes status to “Device Unreachable” and becomes unselectable. I cant create a group when one is unreachable.
Could this be happening because I have them on my guest network? I talked to Amazon support and they could not resolve this.
Any help would be greatly appreciated.
Message 1 of 6
Accepted Solutions
ekhalil
Master
Re: Can’t Add multiroom music speakers to pair of echos on Orbi guest network
If you want to have the speakers on the Guest network you need to allow them to see each other and your LAN. You can configure this in the GUI as follows:
Message 3 of 6
All Replies
Guru
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Review this:
https://community.netgear.com/t5/Orbi/Orbi-and-FEIT-2-4GHz-IoT-wi-fi-bulbs/m-p/1664260/highlight/fal...
Message 2 of 6
ekhalil
Master
Message 3 of 6
Jimdaff
Tutor
This worked perfect!!
Thanks very much
Message 4 of 6
Jimdaff
Tutor
Thanks but I tried ekhalil’s suggestion first because it was so simple. It worked perfect.
Message 5 of 6
ekhalil
Master
You welcome. Glad that this helped!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4360 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
