- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't Connect to SAP on Company VPN since installing ORBI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I work from home. Prior to installing this Orbi router, I would connect to my company VPN, then connect to SAP. Since installing this router. I can still connect to the VPN and all other services work. SAP seems to be the only service I cannot reach. I get a cant reach authority, Secure Network Connection error. If I take my laptop into the company and connect to the network there, both wired and WiFi, everything works. The only problem is at home since installing the Orbi router.
I don't want to go into the office everyday. I need some assistance.
I have explored this with our IT folks, they've reimaged my laptop and upgraded to the latest client. Still no go.
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Put computer in DMZ, still no joy. Uninstalled Orbi, installed new Eero wifi router, Now I can get on SAP. So goodbye Orbi, hello Eero!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Connect to SAP on Company VPN since installing ORBI
If you are not the only person connecting from home, maybe the company IT people have "seen this before"?
Could you please describe what the Orbi is connected to? (brand and model number).
- Mark as New
- Bookmark
- Subscribe
- Permalink
IT is involved, they have re-imaged my laptop and upgraded the client. They have not seen this before. The Orbi is connected to a Netgear CM700 modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not a long term solution, however what happens if you put your VPN PC into the Orbi's DMZ then try to connect to the remote VPN?
Is the PC wired or wireless connected to the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wireless connection. How would I put it in DMZ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Find the IP address for the PC on the RBR and input this IP address in to the DMZ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the Orbi web interface, select the Advanced Tab->Setup->WAN Setup
At the top of the page is a box to enter the IP address of one device. The Orbi will forward every packet that comes in to this device. The typical use of DMZ is for things like web servers. With a strong Windows firewall, most of the junk should bounce off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry Orbi didn't work for you.
Good Luck.
