Orbi WiFi 7 RBE973
Reply
Can't Enable VPN after V1.12.0.18 Update
mnspink
After updating the firmware, I cannot enable VPN (I previously had it enabled).
I re-enabled Dynamic DNS, and when I click the Show Status button, it returns "x.mynetgear.com updated successfully at TIME"
However, when I click on "Enable VPN Service" and then click "Apply", the screen just refreshes and the check-box goes back to unchecked.
Any ideas?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Can't Enable VPN after V1.12.0.18 Update
Did you try to use another web browser?
DarrenM
Message 2 of 4
mnspink
Yes, tried both Firefox and Chrome
Message 3 of 4
DarrenM
Try Internet explore also make sure a pop up blocker or firewall is no causing a issue.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2499 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
