- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't change icons of attached devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't change icons of attached devices
Having the same issue after the latest firmware update in the Router Web GUI. I also do not think the solution is to telnet into the router to fix items. Please note, I had all my devices name correctly and the firmware update change a bunch back. I have also updated the names on the Orbi IOS App, but of course those names do not flow back to the Router GUI so each IOS App we have has different names and I am not going to update all the apps separatedly.
Netgear really needs to step up on their QA. I love the router but the softeware/firmware has always had issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue, just updated to 2.5.0.38 and now all my devices are weird. The table that is being shows on the web portal on the router doesn't match the results from nvram show | grep orbi_dev_name_ntgr[0-999]
At this point I wouldn't mind flushing the list and rebuilding, but I don't want to reset everything on my router, and I'm not sure the Config will restore propperly, as I have a ton of NAT mappings and static IP's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having similar issue.
Can't change device name, model, or icon/type.
Any changes revert,instantly, back to their original settings.
When is then next firmware release?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm downgrading to Firmware 2.3.5.30 resovled my issue with the Device Names not changing. After I downgraded, I was able to change the names as well as the icons. The only issue is, there are not as many icons in the older version.
Once again, Netgear really needs to work on the software side of the house. Their QA stinks. I have no confidence that the next release is going to fix the icon issue and I am now going to miss other critical updates because of their poor updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree regarding Netgear support. I feel abandoned as a Netgear customer and owner of an RBR20 router. The company has probably made the same mistake that has destroyed so many other companies such as Sears and Boeing: placing MBAs and other bean-counters in C-level positions, rather than engineers and others with experience in the core products and services with a focus on quality. Anytime the company culture becomes terminally infected with the Wall Street near-term disease, The End will not be far off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Users should try v2.5.1.8:
https://community.netgear.com/t5/Orbi/Firmware-v2-5-1/m-p/1837488/highlight/true#M78401
Working for me. I didn't have to do a factory reset either. Users should try a factory reset on there systems with v2.5.1.8 loaded if they can't seem to get this working. Clear all browser caches as well. Using Opera for me is working with device naming and icon changing.
For some users which Orbi's out of warranty, give Voxels 3rd party FW or Orbi a try as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
You must be using an RBR50. This thread was originally around the RBR20, for which the latest firmware version is 2.3.5.36. Extrapolating from how quickly the support for the RBR20 was abandoned after the RBR50 came out, I'm sure you'll be joining our orphan ranks soon enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
True...hopefully NG will update the 40 and 20 series Orbi's as well. I would make contact with NG support or file a support ticket about this to let NG know about this for the 40 and 20 series.
Orbi 40 and 20 series are still being updated. Enen though we are seeing FW updates take a while as well on 50 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good idea. I just created ticket 42096291 for them to follow up on this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. You might refer them to this thread for there review as well so they can see others with this same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, updated to the correct router I had. It was a three unit deal from costco, about 6 months ago. Then bought two more access points that matched.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So are you still seeing this with v2.5.1.8 FW loaded on your 50 series Orbi?
@Rikerrock wrote:Sorry, updated to the correct router I had. It was a three unit deal from costco, about 6 months ago. Then bought two more access points that matched.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The one that it says is most up to date: 2.5.0.38. directly from the router interface.
Not sure how to get it to a different version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rikerrock I have the Costco Orbi 3-piece model RBK53, which is an RBR50 router and two RBS50 satellites. If you have this same setup, I suggest manually updating the firmware from https://www.netgear.com/support/product/RBK53#download . The check for update may not see the v2.5.1.8 firmware released about 10 days ago. Download and extract the ZIP files for the RBR50 and RBS50 for v2.5.1.8 from the URL above and install the RBR50-V2.5.1.8.img file manually on the router first. The satellites should automatically upgrade themselves to match, but if they don't, then manually install the RBS50-V2.5.1.8.img file on each of them by logging into the satellite and using its manual update feature.
The v2.5.0.38 firmware device naming was completely messed up, but v2.5.1.8 firmware corrects this issue. This has been mentioned in many other threads on this board (search for "device name" and/or "2.5.0.38").
@Rikerrock wrote:The one that it says is most up to date: 2.5.0.38. directly from the router interface.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Please follow @tomschmidt information on how to get your system updated to v2.5.1.8.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Folks, I am continuing to pursue a resolution of this problem for the RBR20 router with Netgear support. It seems the RBR50 problem was resolved with a firmware upgrade, but to date no corresponding upgrade is available for the RBR20.
I'll post here any significant outcomes (or lack thereof) from my interactions with Support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of the 25+ devices in my network, I can successfully edit the Device Type on most of them. Of the 5 devices affected by this bug, 3 are iHome model ISP6X smartplugs.
One is a Z-Wave bridge manufactured by Powerley, model EB 2.0.
One is a Roku streaming player, model 3. I have three more later model Roku devices that are not affected.
I maintain with Support that the ability to edit the Device Type field should have nothing to do with any particualr device. My ticket is still open with them. Will post ongoing results here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Keith_1952, have you tried a factory reset of the router? If not, I suggest backing up your settings and performing a factory reset to clear any possibly corrupt entries in the firmware that may be blocking editing some of the device names. Once factory reset, go through the manual configuration to the point where your network is functional such that you can then restore the settings from the configuration file saved prior to the factory reset. This process should take about 20 minutes or so to complete. Then try to edit the devices that you were having issues with.
Good luck, report back here with the results.
@Keith_1952 wrote:Of the 25+ devices in my network, I can successfully edit the Device Type on most of them. Of the 5 devices affected by this bug, 3 are iHome model ISP6X smartplugs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest response from Support, regarding the Device Type issue on the RBR20 router:
Hi Keith, Thank you for the information you have provided. I have it all documented and already sent the report to the appropriate department. To let you know ahead, we don't have an ETA of the new firmware but the firmware fix that was added on the model RBR50 which is the device recognition mechanism will also be rolled out soon to all affected models. Regards, Melvin Expert ID: 46221 NETGEAR Senior Support Expert
- Mark as New
- Bookmark
- Subscribe
- Permalink
