Reply
Can't complete setup - Orbi RBR10
Irkmiller
I have followed the iOS app procedure and get through to the screen where the app claims it is checking to see if the "mobile device is connected to the Orbi" and then it fails. If I open my mobile device's settings, it shows it is connected to the Orbi network, the network router and satellites all show solid light ... I'm trying ot hook up toa Suddenlink provided router, and I can't help but wonder if they have a setting/flag set that prevents me from completing the set up. The router supplied is a Altice UBC1326. Suddenlink prevents its users from logging into the admin panel on the supplied router.
Message 1 of 4
Accepted Solutions
Guru
Re: Can't complete setup - Orbi RBR10
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You'll need to contact your ISP for help with there modem
Try using a wired PC and web browser to setup the Orbi system instead of the Orbi app.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 4
All Replies
Guru
Couple of options,
Message 2 of 4
Irkmiller
I'm actually thinking of going with option 4 and buying my own cable modem to replace my ISPs locked out piece of crap. Thanks for pointing out a few things I needed to be aware of to reach this decision. I'm paying $10 a month to lease something I'm not allowed to use to its full potential.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 433 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
