Orbi WiFi 7 RBE973
Reply
Can’t connect IP cam
Rayman2
Initiate
I have two Fujikam IP cameras that won’t connect wirelessly to ORBI. I have read there is an issue getting devices to connect to 2.4 GHz but I can’t see where to turn off the 5 GHz radio. Any help is appreciated.
Message 1 of 4
Accepted Solutions
Rayman2
Initiate
Re: Can’t connect IP cam
The issue was resolved by changing the network in the Fujikam Vimtag software on iPhone.  The app stored the old network setting for the prvious ASUS router.  No issue with ORBI settings. No need to turn off any radios.
Message 3 of 4
All Replies
Guru
Can turn down the 5Ghz radio power by going to Advanced Tab/Advanced Settings/Wireless.
Message 2 of 4
Rayman2
Initiate
Message 3 of 4
Guru
Ah glad you figured it out. Might not have guessed that one. Smiley Tongue Mark this post as solved so others will know if needed.
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2332 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
