Reply
Can't connect to Apple Music via orbit
Adamc104
Hi can someone help? I have recently installed an orbi mesh system, connected to my spectrum router. I can access th einternet but not apple music or download from the app store. Any ideas how to solve this?
Adam
Message 1 of 5
Re: Can't connect to Apple Music via orbit
Does that mean that you have two routers on the same network?
Connect how? What happens when you try?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
Adamc104
Yes the is a spectrum supplied modem, which is then plugged via an ethernet cable into a spectrum wifi router, I have then plugged my orbi into that wifi router. I have also tried bypassing the spectrum router but had the same issue.
Message 3 of 5
So, you have two routers.
What is the spectrum wifi router? The model number.
You may have to put the Orbi into wireless access point mode it you want to avoid local addressing issues.
Or you could remove the spectrum router and connect the Orbi to the modem.
It might also help people if you told them the modem number of your Orbi system.
Just another user.
Message 4 of 5
Guru
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Adam
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 718 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
