Orbi WiFi 7 RBE973
Reply
Can't connect to RBK50 admin after power cut
alphabeta77
Tutor
Hi all,
Had a brief power cut this morning for a few seconds and haven't been able to connect to my Orbi since.
Tried rebooting and same occurs. On WiFi it gives IP configuration failure as an error.
Have tried hardwired Ethernet connection to it and strangely I can access 192.168.1.1 directly for a few minutes on boot, but then it returns to 'cant be reached error' in the browser.
Can't ping the router from another pc, just getting a white pulsing light.
I've attached a screenshot of where it gets to.
Anyone got any ideas on how to fix??
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
alphabeta77
Tutor
Re: Can't connect to RBK50 admin after power cut
Ok, the plot thickens... Finally got in, but I don't recall having 200+ satellites, should I sell 195 of them on eBay?
I can't imagine what the admin app is doing, but clearly it's not right in the head???
Message 2 of 3
Guru
Storms are great at wrecking things.
I'd recommend manually installing the firmware to it, then doing a factory reset, and a reinstall.
If the storm corrupted something in the firmware or settings, this would correct either of those.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 452 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
