Orbi WiFi 7 RBE973
Reply
Can't connect to router settings from Satellite
pmauro
If I try to access the router settings, it doesn't work unless I am next to the router. If I move from a satellite to a location next to my router, I have to turn off the wifi on my mac for a couple of minutes and turn it back on before it will work.
Any ideas?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Can't connect to router settings from Satellite
Have you tried to access the settings using the IP address of 192.168.1.1 instead of orbilogin.net?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
