Reply
Can't disable Orbi guest network
ctheory11
Follower
I'm on firmware 1.8.0.6. Even though I disable the guest network, and orbilogin.com confirms it's disabled, it still shows up and works. Not only that, but you can see all the devices on my main network, even though that option is disabled.
Effectively it's my main network with an easier-to-guess password. Is there any point to using a guest network, beyond not having to give out the password to my main network?
Thanks for your help!
Brian.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: Can't disable Orbi guest network
Hello Ctheory11
You may need to factory reset the unit the guest network should be off if you have it disabled.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2317 views
  • 1 kudo
  • 2 in conversation
Announcements
