- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't enable remote access in Genie app
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the latest firmware on my Orbi system and the newest version of the genie app . When I try to enable remote access in the app it tells me that remote access is not supported by this router.f
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't enable remote access in Genie app
Hello Ctslider
Have you tried to enable it with www.orbilogin.net and then go to Advanced-Advanced Setup-Remote Management?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am experiencing the same issue. Even if I go to the 'Advanced Settings', it does not reflect the change and is limited in its functionality.
.mws
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello msickles
Try going to the full desktop site when in the orbi settings then try to enable the remote managment.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Think that you missed the line in my reply where that was attempted. The remote access is enabled--however it does not reflect properly in the Genie app--so there is a disconnect.
.mws.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello msickles
Oh ok I understand what you are saying now I will look into this if its is some type of bug with the app or if its a issue on the router side.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something that may be related is the 'Network Map' and the discovery on the Orbi.
When I go into the Orbi-app, there is no visibility to the other nodes. You can see '0' devices on the 'Orbi' app and then there is the 'Genie' app that is the configuration element.
If I had to take a guess, there is some deterministic element of the app-side that is not seeing the broadcast-nodes that are part of the configuration. While the 'remote' is not registering, neither is the local.
So between the 'Orbi' app and the 'Genie' app, there is a bit of disconnect.
Overall the box is working fine and am sure that the version and functionality will 'catch-up'.
.mws.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was wondering if you have an update on this issue as I'm have the same complaint?
Thanks
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
