- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't find internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had an issue with FiOS recently and had to reset everything. After I did that the Orbi wouldn't work, so I reset it to factory settings (multiple times before it actually took). I've reached the end of the set-up on the app, but the app is giving me a red 'X' for "Checking internet connection. It can't seem to find the Orbi on the app, however, we have wifi through FiOS that we can use. Any help is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't find internet connection
So, FIOS was reset and then the Orbi no longer worked. Must be a problem with the Orbi. Does FIOS allow the customer to see what devices are connected? (Sorry, I don't have FIOS.) Is "resetting" FIOS totally mechanical, i.e. hold "reset" until the box restarts, or pull and restore power and that's the end of it - no configuration or setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
Power OFF both ISP Modem and Orbi for 1 minute. Then turn ON the ISP modem and let it sync. Power ON the Orbi and try again...walk thru the setup wizard with a wired PC and web browser to set up the RBR.
