- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't get orbi to connect to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm currently with Vodafone for my internet and bought the Orbi system to improve my wifi but I can't get it to connect to the internet. Vodafone are useless customer service wise and seem incapable of providing me with my PPPoE user name and password so I tried connecting the orbi to the vodafone router and switched off the wifi on said router.
Connect everything up, all the satelites connect but it just won't connect to the internet yet my Apple airport extreme does when connected the same way.
Please help I'm more than a little frustrated that this is proving so hard to set up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't get orbi to connect to the internet
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first, then if that fails, try #3...
- Mark as New
- Bookmark
- Subscribe
- Permalink
In Orbi VLAN settings, you need to configure the PPPoE username and password, and also set the vlan tag to 101 (if it's Vodafone UK 🙂 ).
