Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can’t sync RBK 50
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-20
02:09 PM
2020-06-20
02:09 PM
I purchased a second satellite for my RBK 50 system, and can't get the new satellite to sync. Can someone help me with this.
Solved! Go to Solution.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-20
05:58 PM
2020-06-20
05:58 PM
I am using the Orbi App, for adding a satellite. I purchased the satellite from Amazon, it a refurbished one. I push the sync button on the router, and let the light flash for a short period which means it’s ready to sync, then push the sync button on the satellite, it flashes like its trying to sync, but after the period of syncing is over, the light is still white. I don’t want to reset the original set to factory specs, because it may just be the issue with the newer satellite I’m trying to add.
Thanks in advance for your support.
Message 3 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-20
03:05 PM
2020-06-20
03:05 PM
Re: Can’t sync RBK 50
Can you please describe how you are trying to sync the new satellite?
- Using the "sync" button method?
- Using the Orbi web interface (http://orbilogin.net), the bottom menu item: "Add Orbi Satellite"?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-20
05:58 PM
2020-06-20
05:58 PM
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-20
10:43 PM
2020-06-20
10:43 PM
I usually start by pressing the "sync" button on the satellite, then on the router.
Message 4 of 4
Announcements
