Reply
Can you assign a device to a particular satellite
msilberberg
Follower
Is there a way to assign devices to a particular satellite (e.g., I want my ring doorbell to always connect to the closest satellite)?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router, RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite, RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 2
SW_
Prodigy
Prodigy
Re: Can you assign a device to a particular satellite
Yes.  It's possible with different SSIDs.  Just use the target SSID to force/steer the device to nearest satellite.  If you're comfortable with telnet cmds, you can check out this: Separate SSIDs on Guest Network.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1013 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
