- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can you use a wire to connect RBK50 to RBS50?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RBK50 router on ground floor and a RBS50 in the basement. I can not keep them connected wirelessly. Can I use a wire to connect them?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of course:
Be sure to disable Daisy Chain on the RBR.
If you use a LAN switch in between the RBR and RBS, ensure it's a non managed and non Green Ethernet switch.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can you use a wire to connect RBK50 to RBS50?
Correction:
RBR50 and RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of course:
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:
Of course:
I used to use a green switch between mine and switched to a managed switch. Never had an issue and could always max out my speeds. If you run into problems, I'd look at this advice but I wouldn't buy new hardware without trying out your current stuff first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad that yours is working. Others have reported problems with Green Ethernet switches. Managed switches can be used if you disable all IGMP protcols. Yes I have a managed switch as well. For ease of user information, mention of non managed and non green ethernet switches. Users can make there decision from that point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
