Reply
mlbrady30
Cannot access Orbi Admin homepage
I have been trying to log onto my Orbi Router Admin Page. I have a pop up for the Netgear Armor trial that will not go away. Clicking on the "x" in the upper right or the "never remind me again" button does nothing.  I have an RBR50/RBS50 system running firmware V2.7.2.102.  I have cleared my browser and restarted but no change. I can log on as the admin, but then get stuck.
Thanks
Message 1 of 6
Guru
Re: Cannot access Orbi Admin homepage
What browser are you using? Try Edge, FF or Opera.
Be sure to clear out all browser caches before entering the router web page.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
CrimpOn
Sensei
When I updated an Orbi to 2.7.2.102, that annoying Armor popup came coming up, and that almost impossible to read link to "Never mention this again" did work for me.  (I don't remember it being a button, but then I don't remember yesterday's lunch.)
I love my Orbi.
Message 3 of 6
mlbrady30
Thanks,
So far i have tried, Edge, Chrome and Firefox - each with the same results. I cannot get rid of the "pop-up"
Message 4 of 6
Guru
This after a factory reset? I saw this same popup but was able to close it.
What OS are you on? Wndows 10? Do you have a different PC, Pad or Mac by chance?
Message 5 of 6
vajim
Mentor
@mlbrady30 wrote:
Thanks,
cache?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 105 views
  • 0 kudos
  • 4 in conversation
Announcements
