Orbi WiFi 7 RBE973
Reply
Cannot connect some devices to WiFi
michielvdd
Most of my devices (MacBook, iPhone, TV...) connect to my Orbi mesh WiFi without any problem. Other, 'less advanced' devices, like a smart camera, a Google Stadia controller, a connected power plug, a kitchen steamer... just don't connect (or they connect very occasionaly, about 5% of the time). The WiFi network is found by the devices, but I get a "cannot connect" error on every one of these devices.
Right now my Orbi is setup as an access point to my router. At this point, I had to set up a different AP with a different SSID for these 'less advanced' devices, which is not my preferred solution.
Anyone with any ideas or similar problems?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: Cannot connect some devices to WiFi
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 5 of 8
All Replies
CrimpOn
Guru
There is a potential solution for "cannot connect" if the devices recognize only 2.4G networks.  Connect about 5% of the time is an entirely different problem.
Message 2 of 8
michielvdd
What would the solution be for 2.4GHz devices?
Message 3 of 8
vajim
Master
If you're talking about devices which will only connect via 2.4, one possible solution is a Tenda extender.   Google it
With a true Mesh system the router combines both the 2.4 and 5g into one SSID and it decides which  frequency to assign the device.
The Tenda extender will create a separate visible SSID at 2.4.
Good luck
Message 4 of 8
Guru
Message 5 of 8
michielvdd
Thank you very much for your reply!
I think I have found the problem. I changed the 2.4GHz channel to 11 and the 5GHz channel to 48 and this seems to have solved the problem. When I change the channels back to their original value, I can replicate the issue, so I'm pretty sure the channel was causing the issue.
Thanks for the help!
Message 6 of 8
Guru
Glad it's working now. Enjoy. Smiley Wink
Message 7 of 8
vajim
Master
I hope your neighbors don't do the same
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2059 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
