Orbi WiFi 7 RBE973
Reply
Cannot connect to internet
ScrantonMark
I attempted to install the Orbi system (with one satellite) yesterday and I have been unable to connect to the internet.  The installation went smoothly.  I even made it to the point where I could rename it and add my own password.
The two Orbi units seem to be working you can select them as your wifi option in addition I ran the speed check and that worked.   I checked the cable modem and it recognizes the Orbi as connected.  I know the internet is working I have a second router connected to that same modem and it works fine.
The error message reads something to the effect of "Unable to find secure connection to the internet"
I have rebooted the cable modem several times and I have shut both Orbi units off.
Short of doing a hard reset and starting over I am not sure what other steps to try
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Accepted Solutions
Fl1ntstone
Apprentice
Re: Cannot connect to internet
Hi,
It sounds like as you already have a router then you need to configure your Orbi as an Access Point(AP) only?  If you can login to your Orbi via a web browser, you will see an option to enable AP mode.  Try that and see what happens? 🙂
CheerZ
Message 2 of 5
All Replies
Fl1ntstone
Apprentice
Hi,
CheerZ
Message 2 of 5
Guru
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router at the modem, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 3 of 5
ScrantonMark
Yes it was the two routers in conflict after a bit ot trail and error i got the Orbi in AP mode and it works great.  My Cable modem/router is probably 5-6 years old I am surprised that checking this is not part of the setup instructions I am hardly cutting edge with my setup .
Message 4 of 5
Guru
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3031 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
