- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot find RBR50 (rbk53) router in my network
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Milan81 wrote:
I tried to change ASUS ip to 192.168.1.2- it works, but still no RBR in the list of the devices.
I don't understand that comment. Why would you change the "ASUS IP" and what are you referring to here--the router?
In any case... Do the following:
1. Factory reset the Orbi using the paperclip method. Hold the clip in for a long time until the power led blinks amber.
2. Connect the Orbi Internet/WAN port to your ASUS router.
3. Power-on Orbi.
4. Connect a laptop or desktop to the Orbi's WIFI or an Orbi LAN port.
5. Use a browser on your desktop or PC and connect to the Orbi's LAN address and setup Orbi. If the ASUS LAN is using 192.168.1.X, then Orbi will be at 10.0.0.1 and your desktop or PC should have an address like 10.0.0.X.
6. Change Orbi to Access Point mode.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Cannot find RBR50 (rbk53) router in my network
You are supposed to wire your router to the Internet/WAN port on the RBR in AP mode. If you don't, the magenta light will stay on.
The only thing I can think of that would cause the issue you are seeing is if you had set a static IP on the RBR's LAN or WAN interface prior to switching to AP mode, and you used an IP that conflicts with the ASUS.
You might need to reset at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When I was setting up RBR I didn’t put any static IPs for it... just chose AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
3. Power-on Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You wrote that ASUS might be conflicting with RBR, so I thought maybe if I changed ASUS default IP RBR would be visible at 192.168.1.1.
Ok, it doesn’t matter right now cause I did this factory reset, set up the system from the very beginning just like you described and it seems working now! So thank you very much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
