- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot get RBR50 to use IPv6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just bought/installed a new RBK50 router w/satellite to replace my old Nighthawk R7000. It's up and running fine (on IPv4) but I cannot get it to acquire an IPv6 address from my Comcast cable modem (Arris TG1682G). This worked fine with the Nighthawk router. I verified that Comcast is willing to issue an IPv6 address by connecting my desktop directly to the Comcast modem... that all works fine. But the IPv6 status on the Orbi continually shows:
"Router's IPv6 Addresss on WAN:
Not Available"
I've tried setting the IPv6 config to autodetect and also manually to DHCP. After making changes I've rebooted everything and brought things up in an orderly fashion.
Any suggestions?
I'm planning to file a formal support case, but I've had some trouble getting the new router registered under my account. I'm dealing with that separately but figured it was worth reaching out here in case that takes a while to resolve.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your ISP modem in bridge mode? The modem already has a router built in. It needs to be bridge fully do the RBR can take advantage of IPv6.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot get RBR50 to use IPv6
Thanks for the response...
Sorry - I should have mentioned the modem config. Bridge mode is disabled on the modem. All modem wifi radios are off (both private nets and Xfinity public hotspot). Orbi is in Router mode. So it picks up an IPv4 address from the modem and then routes everything fine via NAT (i.e. no double-NAT). If double NAT was an issue, it wouldn't work for IPv4, right? And as I also mentioned, this configuration worked for IPv6 when using my NG R7000 instead of the ORBI for routing/wifi. I shouldn't have to set the ORBI to AP mode unless I had another wireless network active, right?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I changed the ORBI to AP mode, and it's working! Thanks for the help.
I still thought that AP mode was only needed if I already had a wireless network running, so I'm still confused on that. Perhaps the Comcast modem has something configured that I can't find that's tripping me up. Oh well, thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rspnetgorbi wrote:I've tried setting the IPv6 config to autodetect and also manually to DHCP. After making changes I've rebooted everything and brought things up in an orderly fashion.
Wow, so many choices for ipv6! Looks like DHCP is what you are supposed to use: https://cirw.in/blog/ipv6-config
I don't get that part about "takes a few minutes to take effect". Like, how many minutes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF your getting IPv6 when the Orbi is in AP modem, then your modem isn't bridged.
Glad this configuration works for you.
@rspnetgorbi wrote:Well, I changed the ORBI to AP mode, and it's working! Thanks for the help.
