Orbi WiFi 7 RBE973
Reply
Cannot log into Admin page on RBR40
Docmarker
Hi,
I cannot log into my admin page. I get to the security questions and I do not have the answer to one of them. "First netgear product purchased'? I have tried multiple on/offs, used the app, reset the router, etc. Got on line and some orbi website wanted money to fix it and protect it. Stopped right there. Any suggestions? All of this started as I was using a Trend home network program on my MacBook and it showed me that there are items using the WIFI that I do not own.
Thanks!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Cannot log into Admin page on RBR40
Wire connect a PC to the router and factory reset the router using the back push pin button. Press the button for 15 seconds then release. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Docmarker
This worked. Thanks so much!
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 686 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
