Orbi WiFi 7 RBE973
Reply
Cant connect to my company vpn
makelo3983
Follower
I am not able to connect to my Company's VPN using ORBI routre.  There is no issue w/ internet connection or streaming, only my VPN connection.  I tried calling my ISP to see if there is any issue on there side, but they indicated not.  It appears that i am on the most recent firmware:
V2.3.5.26
Can you please help?
-thanks
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Cant connect to my company vpn
Can you please describe how the Orbi is connected to the internet?
brand/model of modem?
Are you able to connect to the company VPN from other locations?  (Starbucks, airport, hotel?)
Thanks
Message 2 of 3
schumaku
Guru
Define "company VPN" e.g. vendor, VPN client in use, ... and if you have good connections to the corporate IT challenge them which protocols the prefer, allow, or deny. In the past, consumer routers [also Netgear was invovled] failed to allow some protocols to pass, despite of some "VPN passthrough" allowance. Without more insight, there is not much Netgear has to investigate.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 580 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
