Reply
Cat6 distance between my orbi router and original router
Bkhatton1
Follower
I have the RBR40 system. Is there a max distance you can place you wired cat6 orbi router from your original WiFi router? I know max run on cat 6 is 328 feet. But does it matter to the routers? I’m not talking about the satellites.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
schumaku
Guru
Re: Cat6 distance between my orbi router and original router
Yes, it's an Ethernet link - so anything up to this length must remain workable.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 345 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
