Orbi WiFi 7 RBE973
Reply
CenturyLink Fiber and Netgear ORBI 100Mbps cap
I am using my Netgear orbi instead of the provided modem/router combo CenturyLink provides. I don't expect 1000Mbps by any means but I would expect to see speeds higher than 100Mbps. It appears that is the cap at which I am getting.
Any thoughts?
I have it set-up to use PPPoE and VLAN tagging, but everything else is default.
Message 1 of 3
ekhalil
Master
Re: CenturyLink Fiber and Netgear ORBI 100Mbps cap
- Is this a wired or wireless speed?
- What speed do you get when you do speed test in the Orbi app (Internet Speed) or in orbilogin.net under >>ADVANCED>>Setup>>QoS Setup?
Message 2 of 3
This is wireless speed. Attached are the two different tests:
The OOKLA test looks better but still not where I would expect. I'd expect soemthing at least at 400Mbps download speed. It sounds like that's what others are getting too on CenturyLink Fiber with orbi, removing the CenturyLink modem/router from the picture.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2450 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
