Ixmaninc's avatar
Ixmaninc
Change Default User Name RBR50 ORBI
It's easy enough to change the default ORBI user password, but is there a way to change the "admin" user name?
  • FURRYe38's avatar
    No. Admin is set by default and can't be changed.
    • Utrera's avatar
      Utrera
      Initiate
      Is Netgear going to step up to the plate and allow users to change the user name? Most security guru's highly reccommend that the default user name (as well as the default password) be changed when setting up a new WiFi system.
      • CrimpOn's avatar
        CrimpOn
        You are not going to be happy.  Netgear shows no interest in changing the user name from "admin".
        They may feel that the user can get the same level of 'security' by specifying a sufficiently complex password.
        (Mine is 25 characters long, and my calculation is that it will take about 4 billion years to try every possible combination.)
        If you want to "hack" the Orbi, then it is possible to change the web login from "admin" using telnet commands.  I have never it myself, so I have no idea if it survives power restarts.  It certainly will not survive a "Factory Reset" (nothing does).
