- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Change connection on Iphone to 2.4GHz in Orby app
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Change connection on Iphone to 2.4GHz in Orby app
Solved: Re: Orbi and FEIT 2.4GHz IoT wi-fi bulbs - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this as well from a PC and web browser:
@Hrannarm wrote:
Hi. I am trying to connect my security cameras to my iPhone and it says I need to have my phone on 2.4GHz, how can i switch to 2.4GHz in my mobile orby app??
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would help if you specify the model of camera. In my (limited) experience, a lot of cameras have their "app" display a smart code and the camera is pointed at the smart code to login.
Also, just a "technicality", but the immediate goal is to connect the camera to WiFi, correct? Later, the iPhone can connect to the camera, either from at home or from elsewhere?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once you disable the 5Ghz SSID broadcast, save and apply. Do a "Forget this Network" on your phone or pad. Disable the wifi radio on the phone or pad, then re-enable it, then reconnect to the Orbi WiFi. The phone or pad should be now connected to the 2.4Ghz frequency.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Hrannarm wrote:
They have there own app, denali I think it is and they say that I can only add the camera on 2.4Ghz
The box that now has "Freyjubrunnur1..." What was there before?
So, what happened when you just put in the Orbi WiFi name and password and click on "Done"?
