Reply
Highlighted
Changing ISP Ip Address Using Orbi Router
Hello,
So I am wondering if there is a  way to change the ip address assigned by the ISP (which is Charter Communications) using the Orbi Router Settings? I had read this can be done by changing the MAC address of the router then rebooting it. Are there any thoughts on this? Thank you.
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 2
Highlighted
Guru
Re: Changing ISP Ip Address Using Orbi Router
You can't change the WAN IP address your ISP gives you. Based on a time frame and there policies, it only changes after a certain period of time that they set in there DHCP services for there customers. When this happens usually the modem would need to be rebooted, they may push a reboot or you can power it off then back on after 30 seconds.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 709 views
  • 0 kudos
  • 2 in conversation
Announcements
