Orbi WiFi 7 RBE973
Reply
Changing ISP from Virgin to BT FTTP
rapshank1882
Hi - This is my first post, so please go easy 🙂
I currently have Virgin Media (350 down/30 up) with Orbi RBR850 with one satelite running in router mode - works like a dream.  My Virgin SH3 connects directly into the Orbi router via ethernet cable.  I have no fancy setup, pretty my out-of-the-box Orbi config through the mobile app.
Virgin is out of contract and I can get BT FTTP for cheaper plus higher speeds, so I plan to make the change.
My question is, when BT install the new line into my office, can I plug directly from the ONT into Orbi via the lan cable or do I need to use their modem/router/hub then connect to Orbi via lan cable as per my current Virgin setup?
Finally, if the question above is yes, will my Orbi config 'continue' as normal (wifi names, passwords etc) once it picks up the new super charged speeds?!
Thanks in advanced!
Chris
RBR850 - V3.2.18.1_1.4.14
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
rapshank1882
Re: Changing ISP from Virgin to BT FTTP
Bingo!  bthomehub@btbroadband.com is the required login for for PPPoE (blank password) and all working like a charm 🙂
Thanks, Furry
Message 9 of 10
All Replies
Guru
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
AT most you'll need to power OFF the RBR, connect up to the new modem, power ON the modem and RBR and it should connect.
Contact the ISP for help and information regarding there modems and connecting up any external routers. Some Modems have built in routers as well.
Thank you.
Message 2 of 10
rapshank1882
Thanks, Furry will give it a try in a month from now!
Message 3 of 10
CrimpOn
Guru
Yes, the Orbi should connect directly to the fiber ONT.  Fiber is installed in numerous ways.  Like cable modems, sometimes the ONT is "only an ONT" and the ISP wants to provide a separate box which includes a router, WiFi, etherent ports, etc. etc.  Other times, that ONT has the router and WiFi built in.  Might be worth a call to BT to ask specifically what they intend to install.  They are gaining a customer. Perhaps they will be included to answer questions. (Maybe a steady stream of customers?)
The Orbi WiFi name (SSID) and password will remain unchanged.  There is a chance that the Orbi's LAN IP subnet may change. When the Orbi receives an IP address on its WAN port, it selects a different private IP range for the LAN side.  Generally, if the Orbi is connected directly to the internet and receives a truly public IP address, it will choose 192.168.1.x for the LAN side.  If it is connected to a router which gives the Orbi a 192.168.1.x IP address, then it will select 10.0.0.x for the LAN side.
If you have done nothing to configure the LAN side, then your devices should get new IP's and continue to work.
Message 4 of 10
rapshank1882
Thanks for the detailed description! My new line isn't installed until July 14, so I won't be able confirm or accept until then. However, from yours and Furry's posts I'm pretty confident now.
Thanks again.
Message 5 of 10
Guru
Let us know how it goes...
Message 6 of 10
rapshank1882
Hi Guys
Install day has come and the new FTTP is installed.  However, plugging the ethernet fron ONT to Orbi isn'y working.  No IP is being assigned and the Orbi flashes white and then solid purple.  I have tried switching off Orbi and ONT for 5 minutes a couple of times but not luck.
Do I need to reset the Orbi and carry out a new install or is there any authentication I am missing?
There are a few other posts advising it worked first time direct from ONT to Orbi, some had to use username and password/blank password PPPOE etc etc..
Thanks
Chris
Message 7 of 10
Guru
Contact your ISP to see if PPPoE on the Orbi is required or not...
Message 8 of 10
rapshank1882
Thanks, Furry
Message 9 of 10
Guru
Awesome.
Please mark your thread as solved so others will know.
Enjoy.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2386 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
