Orbi WiFi 7 RBE973
Reply
Choosing the best channels
marcosoul
Guide
Anyone have any recommendations on how I can pick the best 2.4Ghz and 5Ghz channels? Is there free software that I can use in either Windows or Mac?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
martyfp
Luminary
Re: Choosing the best channels
I use the free version of Acrylic on a windows laptop - it works really well.  It misses some advanced features of the full version but is more than sufficient for scanning channels etc.
Message 2 of 4
Rattler
Guide
For the Mac, I use NetSpot and it works great. It will show all the nerby access points, channels, strength, etc. The free version is fine. It's also cool to "Map" your wifi with the paid version.
NetSpot
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 3 of 4
guzzijason
Apprentice
Also, on a Mac, there are some pretty decent tools built-in!
Hold down the "option" key, and then click on the WiFi menu item. You'll see addtional items under the menu. Click "Open Wireless Diagnostics..." Then, with Wireless Diagnostics open, click on the "Window" menu to find various other tools. I have found the "Scan" tool to be particularly useful.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3404 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
