- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Chromecast cannot connect to Orbi RBK 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought an Orbi RBK13 (RBR10 + 2xRBS10) and I have gotten all of my devices to connect except for my two V2 Chromecasts. I tried unplugging the satellites thinking that there maybe an issue of them being to close to the router but that still did not work. I saw some other post of people having issues with chromecast and tried those solutions but no luck there either. Anyone have any suggestions?
Frimware is v2.3.6.18 (up to date)
My current settings are:
Advanced Wireless Settings (2.4GHz b/g/n) | |
Enable SSID Broadcast (enabled) | |
Enable 20/40 MHz Coexistence (disabled) | |
Enable WMM (Wi-Fi multimedia) settings (enabled) | |
CTS/RTS Threshold (1-2347) (2347) | |
Preamble Mode (Automatic) |
Transmit Power Control (100%) | |
Advanced Wireless Settings (5GHz 802.11a/n/ac) | |
Preamble Mode (Automatic) | |
Backhaul Topology | |
Enable Daisy-Chain Topology (enabled) | |
Backhaul Password | |
Orbi can generate a new hidden password to improve security for its backhaul connection. | |
WARNING: Generating a new password might cause the Orbi satellite to lose connection from the Orbi router. To reconnect, use the Sync button. | |
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices (disabled) | |
Enable MU-MIMO (disabled) | |
Enable Fast Roaming (disabled) |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
WPA and TKIP should work with it.I tried with Daisy chain enabled and disabled and it did not work. Interestly I tried to enable guest access and log into the guest network with the same securty and password (I set the guest network up the same as the normal network) and it connected fine and I can cast from other devices. No idea why it works but its working now. Thanks for your help @FURRYe38 !
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Chromecast cannot connect to Orbi RBK 13
What happens if you tempoarily disable WPA on the RBR. Try to connect the devices to the open SSID name?
Then re-enable WPA2 and AES only on the RBR then try to re-connect the devices to the SSID name and input the PW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So when the network is open the chromecast can connect. I switched it back to WPA2-PSK [AES] and put in a password and it fails to connect. This is the same securty and password I had on my old router and that worked just fine. Obviously I can't leave my wifi without a password so any idea whats going on? Also thanks for responding!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does WPA1 and TPIK work with the device?
Is Dasiy chaing enabled on the RBR by chance? Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, thats crazy huh?
What happens if you disable Guest network? Just curious if it will connect to the main wifi after this.
Glad you got it working. Odd process to get those working.
