Reply
Circle enabled, internet go offline intermittently RBR50
Pokemon888
Guide
Does anyone having problem with the RBR50 offline intermittently when Circle enable ?
Symptom :
When Circle enable, devices went offline. I have checked devices, wifi icon is on but unable to connect to the internet.
ie. Checked computer, wifi icon still on and connected to correct SSID.  IOS devices appearred to be connect to the router.
After about 12 to 15mins internet back online again. This happened throughout the day.  For now I have disabled Circle and internet working fine without any disruption.
The point is I want to use Circle 😞
Hardware :
RBR50
FW : V2.5.1.16
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Circle enabled, internet go offline intermittently RBR50
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Disable circle as there has been long posts about circle causing problems. File a support ticket with NG as well to let them know.
Good Luck
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX80 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 216 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
